Kompakt Feature Requests
Hey, I know there already are some feature requests in other threads but I thought maybe there could be a dedicated one and I also wanted to drop some. So…
  1. Recurring events in the calendar app should be possible.
  2. There should be a stopwatch and a timer as part of the clock app.
  3. It would be nice if there was a way to switch on the background light via a hardware input (volume up + on/off or something like that). I found myself in the dark once and wanted to switch on the flashlight but couldn’t even read the display because the light was off.
  4. It would be cool if it was possible to assign the little front LED to different things like notifications. It would be a nice way to avoid having to unlock the phone to check if anything happened. Right now it only indicates “low” battery meaning there is still 12h left (at least when I checked) which is not that relevant for me. At least for me it would be much more useful if it would tell me if there are pending notifications as I mainly use Signal (Molly) as a means of communication on the Kompakt and have to check every now and then.
  5. A selection of shorter notification sounds would be nice. I really like the general sound design of the Kompakt. However, all the notification sounds are somewhat long which can get annoying when receiving lots of messages in a row. Some really short and snappy sound like the unlocking click would be great. Maybe the sound of Hyōshigi (Japanese wood clappers) would be fitting.
  6. Being able to kill apps without menu diving could be helpful. I don’t know how relevant this is but as I use side loaded apps I would appreciate an easy way to shut them down when I’m done using them.
  7. (I know this has been requested before but… ) Custom icons for side loaded apps would be cool. Some of them end up being just black squares which makes navigation more tedious. Maybe just have a selection of generic icons one can assign. For example just have a color inverted (black background white logo) version of the music player icon that one could use for Spotify or other services like that.
Other things I noticed but don’t really care about since I don’t use the apps:
  • It should be possible to remove the meditation cards from the reader app. At least the ones in all the languages I don’t speak are just clutter.
  • The keyboard does not show suggestions when I use Molly (even when private keyboard is deactivated). Don’t know why that is but I installed SwiftKeyboard anyway.
All that being said, I have to say that I really really love the Kompakt so far. It’s such a great everyday companion <3
Re 3, might also make sense to have some key combo for the flashlight.
I completely agree with that.
I am of the same opinion.
Great suggestions - I agree with a lot of what you’ve said here.
I doubly support the shorter notification sounds, countdown timer, notification LED, and custom sideloaded app icons!
@fuzz Thanks for taking the time to write all of this out. I have passed it on to our team :slight_smile:
Thanks, Urszula! :smiling_face:
