Kompakt emits RF while offline+ is enabled
Hello so I discovered that the kompakt blasts RF everytime you wakeup the screen/unlock device. It seems to do it with airplane mode and even the offline+ enabled. It does it briefly and then stops but this still is an issue regardless.
Mudita please fix this!
WHOA! That’s really bad! I feel betrayed now :confounded:
I thought this was a privacy-oriented phone ??? First the Sentry and now this ???
If this isn’t being fixed immediately, Mudita should rename the switch to “Online-”
I wonder what is the root cause, but there could be several explanations.
First of all, you’re in the near field of the phone. A bit too close for the meter, they typically are for far field (physics of the near field are messed up). 1 V/m is kinda small.
I’m not sure if some display controller voltage switch wouldn’t cause a blip like this.
Could be some brief power-cycle of some of the components.
Could be another type of software issue.
Retry at 1 m distance please.
If you worry about actual traffic being sent out, try capturing traffic. And verify what’s the frequency of that spike because EMF is everything. Is 60 mW/m2 considered data transmission capable power density?
Yeah the sentry thing and this definitely has me bummed. I dont want to be spiked with RF everytime I unlock the device for no reason…
These consumer meters dont have great range so this distance is just fine, its not the first time of me using this meter. I am not talking about EF/EMF, if you look at the larger “RF” reading that is what im talking about. There should be nothing causing this RF blip especially with the offline+ enabled. I wonder if the bluetooth radio is waking up briefly and then shutting off which shouldnt be happening.
But RF is specifically crazy in the first meter from an appliance. Whenever you measure throughput in wireless, it must also be at least one meter away - especially with MIMO.
Could be that one of the software-driven things cycles briefly and that would mean it’s some sneaky bug.
Not necessarily a security or health issue though, let’s compare the amount of energy emitted with any regular BT/Wi-Fi/GSM/LTE signalling/transmission.
I’m kind of perfectionist myself so I agree, ideally the meter would be quiet.
I can’t falsify the idea of some IC causing such RF artifact in the near field. By the end of the day, everything is EMF - including RF, light, and your own body heat.
I vote for a bug.
I’ve asked for feedback from our team about this & here’s what they had to say:
The TL;DR version is this:
When Offline+ is switched on, Mudita Kompakt is physically disconnected from all radios (cellular, Wi-Fi, Bluetooth, mics). It cannot send or receive any data.
Like any powered electronic device, it still emits tiny, harmless electromagnetic noise simply because electricity is flowing through its circuits. That is normal physics, not a bug, and it carries zero data. No tracking, no transmission, no connectivity.
Here’s the full take from the team:
  1. The Offline+ Switch is Absolute (No Data Transmission)
    When you activate the physical Offline+ switch on the side of the Kompakt, it executes a hard, electrical disconnect of the GSM modem, Wi-Fi, Bluetooth, and microphones.
    The antennas are physically cut off from the power source.
  • Because of this hardware-level severance, it is physically impossible for the phone to transmit or receive cellular data, location pings, or wireless communications. Your privacy is fully secured.
  1. General RF/EMI vs. Cellular Transmission
    As you correctly noted, any device with a battery and a circuit board generates a localized electromagnetic field (EMI) simply by having electricity flow through it.
  • The processor computing background tasks (like keeping the time), the battery regulating power, and even the E-Ink display refreshing the screen all create tiny electromagnetic fluctuations.
  • Highly sensitive RF and EMF meters will pick up this “background noise” from the Kompakt, just as they would from a digital watch, a basic alarm clock, or a pocket calculator.
  1. Physics, Not a Bug
    Because this emission is a natural byproduct of electricity moving through physical circuits, it is indeed a matter of physics and not a software behavior that can be “patched” or “fixed.” As long as the device is powered on, it will emit a baseline level of electromagnetic noise.
    However, we want to reiterate that this localized electrical noise contains zero data. It is not communicating with cell towers, routers, or other devices. The phone remains in a state of complete digital isolation.
I just tested on my 2nd mudita kompakt running lineageos and that’s not true. The wifi and Bluetooth remains active when offline+ is enabled. Only cellular is hard cut so this is why I’m finding RF when I wake the device. I’m able to connect to BT devices and different wifi signals while in offline+. So it seems muditaos is just hiding those toggles visibly only. My concern is mostly RF exposure health wise when it’s off since I expect it to truly be off but that doesn’t appear to be the case.
The website states “Mudita Kompakt ensures no tracking, no ads, and no distracting apps. It features a dedicated button for a hardware-level cutoff of microphones and the GSM modem, while also disabling the camera, WiFi, and Bluetooth at the software level”
I knew it. Fake privacy. But when someone points it out, all hell breaks loose.
I’m now only about 2% away from selling the Kompakt.
Yeah, we’re gonna need some answers here, maybe from another mudita developer that will address this issue with the seriousness it deserves.
Edit: tone. I’m upset but admittedly came in too spicy
Can somebody explain to a simple user what this is all about? I just tried several apps I normally use with WLAN (Signal/Molly, WhatsApp, Syncthing) and they didn’t work when offline+ was enabled.
Well that might indicate that not all Kompakts are the same. It would also explain why the spam blocker works for @urszula but not for me. If that is so, then it raises even more questions, especially about the quality assurance at Mudita. Looks like some users are lucky, others aren’t.
But @jordan might have a better explanation, I’m really just guessing.
Same here. Offline + seems to work as advertised on my MK.
If antennas are physically cut, it could potentially be that a screen wake initiates calling base station but obviously failing - like trying to play radio on your hi-fi system with antena being unplugged. @urszula
Oh, that seems to explain why you can enable it with Lineage. Software level could mean that it’s shut down and regular MK OS user can’t enable it back by himself.
Plus, Wi-Fi/BT module has its own antenna(s) as far as I’m aware. That would explain why Lineage can not just enable it, but it also works fine when enabled. Keep in mind this is tinkering level expert and if anything is shut at the software level, there’s a way to no-shut it.
That’s interesting. I’m looking forward to the next response. My guess is that the GSM antenna is cut off but the GSM module is not shut down so when the screen is awake, phone may try to do some signalling or sync for whatever was supressed for inactivity period, and fails bc antenna. Again, the measured RF value looked small IMO. If I’m not wrong, that could be tens of dB below zero. And after 1 meter it’s down by another 30-40 dB. That’s not usable for any transmission unless you have a base station in your backyard.
I’d recommend adjusting MK OS so that GSM/LTE is also shut at the software level for completness, and next piece of hardware could also cut off Wi-Fi/BT module antenna for completness on that end (i.e. if someone tries to hack the switch :wink: ).
Not being serious, I still prefer MK over US/China/Israel/Google espionage.
Edit: being serious again, I remembered RF is 3 kHz - 3 THz. That would make GPT sound credible when it says that CPU clock, switching regulators and alike could emit RF noise. More, but not AI slop (just oldschool slop): Electromagnetic interference - Wikipedia
@jordan please compare with regular smartphone in the same manner (“gun to head”), and please measure both at 1, 2, 5 meters:
  • when one or another is idle but all is on,
  • when one or another is idle but MK is in Offline+,
  • when one or another has screen woke up when all is on,
  • when one or another has screen woke up but MK is in Offline+.
It adds up to 24 measurements. Ignore 5 meter one, and it’s 18 measurements. This might still sound like a lot, but will give some more insight. Privacy violation under hardware switch clout is a too serious claim to not back it with a serious proof.
I went ahead and recorded a vid https://youtu.be/kc_TTcEMLBA
To clarify cellular and microphones are a hardware cut and offline+ works successfully for those. The remaining wireless radios (wifi and Bluetooth) are not on a hardware cut.
What I would like to see from mudita is if there’s a way on muditaOS that prevents those wireless radios from waking up on every wake of the screen at least when offline+ is enabled. I have them manually turned off too but they still come alive and then shut back down. Would like to be totally RF free from those radios when offline+ is enabled is all!
I did test other devices and they have similar behaviors with turning on briefly even when airplane mode is enabled.
Thanks for pointing this out. I will ask our team about this.
Wow that’s pretty bad. The claims about it being a hardware switch should be reverted and removed from the website and other marketing materials, this video proves it is not a hardware switch… As to how this happened my guess is the hardware was not fully designed in-house but the motherboard was partially designed by some chinese manufacturer. Or maybe it’s not even possible to disable wifi and bluetooth with a hardware switch on this SOC
I’ve reached out to the team and I’m waiting for some feedback.
At this point I’d be curious to see if also microphones are really switched off on the hardware level. Can you verify on lineageos? Thanks!
How is this fake privacy? This was clearly stated on all product pages and I was well aware of it before I purchased the Kompakt. They didn’t try to hide this fact at all in marketing. If absolute, complete, hardware-level privacy is your concern, the Kompakt is not the product for you.
