Had a quick question about the Kompakt calendar, not the stock calendar but the other one, in the notifications it shows you can change the notifications sound, but when you do it does not save and goes back to whatever sound you have set for your text notifications. I usually have text notifications silenced so I want a different sound for when an event happens
I am unfamiliar with that calendar. I use the Etar app.
I don’t think the Kompakt allows different notification sounds amongst apps. One sound is applied globally for notifications.
yeah I don’t mean the stock calendar, there is another calendar created for the kompakt @david-ger is the developer hoping he can clarify!
@Cardiomannisback the Mudita OS itself is the limitation here. It allows only one notification sound to be selected for all apps. This can’t be changed by a third party app, including KompaktCalendar.
Ah gotcha, regardless love this calendar, thank you for your hard work ![]()
I actually ended up deleting the calendar because it reminds you of the even prior to it happening and then when it happens, I am finding that it is too distractive. I don’t need to be reminded twice of an event, unless I am missing something I decided to go back to the stock calendar
