Is it possible just copy ebooks directly (without Mudita Center)?
Hello, is it possible to copy EPUB/PDF files directly into the Ebooks directory without using Mudita Center, so that they appear in the E-reader app?
I did this and had no problems with it. I haven’t tried with PDF.
I especially do this type of stuff with audio files.
Are you just copying to Ebooks directory?
When I’m coping files to Music, Audiobooks, DCIM/Camera, and Recording works. These files appear in their apps (Music, Audio Reader, Camera, Recorder), but seems like in my case E-reader app doesn’t scan Ebooks directory.
The only way I could copy books (epub, pdf) is using Mudita Center.
You can use Windows Explorer on a PC. I used that to upload boarding passes & event tickets.
Thank you for the hint! I tried OpenMTP over USB as well (same protcol Windows Explorer uses), it just gets stuck.
Only Mudita Center works.
I’m just trying to rsync my ebooks over ssh (sideloaded termux to copy files), but seems like E-reader doesn’t scan Ebooks directory. Could you please ask developers of E-reader app how it works?
Thank you!
Try legacy mode instead of kalem. And quit apps that require syncing if u have running (like dropbox, drive + mac preview app sometimes gets in the way of openmtp).
