Is a Data Plan Required for Mudita Pure? Or can we just have talk and text plan?
No i dont think it is required
Thanks but I need to know for certain before I preorder because we don’t want the internet at all, not even the temptation to use it as a hotspot. Thank you.
No, you don’t need a data plan, as it isn’t required by any smartphone or feature phone manufacturer.
@jcxm360 Thanks for your question. If you don’t plan on using the tethering option, then you’ll be fine with just a simple talk & text plan. However, if you do plan on using the Mudita Pure to tether to a laptop of computer, then a data plan might be something to consider because, without one, you may incur additional, unnecessary charges, if you DO decide to tether.
Perfect. Thank you
