I found this. So I am impatient to see in mudita.
most of them seem to be wanders apps with a few by mudita and a few other developers
i thought there was a worry that wanders apps are vibe coded?
not a slight btw i just read that some users worried about safety of such apps
Good point. It is neccesary to be worry about vibe code apps if It is offline like almost all wander’s app? Anyway, It is a good question in this way for the Inkapps store developers. On the other hand, Is the wander’s apps and others in github? I Checked some wander’s app and yes, so It is possible to be safety at the open source to look in.
The apps are here!!! Seems like Mudita is taking a cautious/slow approach, given the limited # of initial apps. I’m happy to see this ![]()
I was one of those users and Wander explained that while he does use AI in some of his coding process, he is an actual coder himself and he’s reading the code back and checking for problems. The apps are also usually offline and often times built on top of existing open source code (Messaging using Signal, Atlas using CoMaps, etc). Personally that’s enough assurance for me, I think if a developer actually knows how to code then AI could be a useful tool instead of a net negative. It’s the internet-connected projects vibecoded by people who don’t actually have any coding skill that I’d be worried about.
cheers fair enough
I’m glad that everyone seems excited ![]()
We can’t wait for you guys to try it out.
I just glanced over that InkApps page, and the apps look awesome and carefully created & curated. I’m a Sudoku fanatic so looking forward to that, as well as the star map and soundscape app. Great work Mudita!
I would like to add from Mudita’s side that, as Mudita, we want to offer well-made apps for Mudita Kompakt. Every app, including the ones we build ourselves, goes through a manual review by our team, with automated checks where possible. We focus on how the app works and whether it meets our requirements for being listed. Whether the idea behind an app is something you’d find useful on your Mudita Kompakt is up to you.
For example, apps need to be suitable for a general audience, and developers need to tell us whether their app works offline and whether it uses features like autoplay or infinite scroll. You can see those details before installing an app.
You can also take a look at our FAQ page related to InkApps:
Of course, issues can still surface after an app is listed. If you spot a bug or something that doesn’t match the app’s description, you can report it directly from the app’s page in InkApps so our team can take a look.
I can speak to this directly. Mudita was very slow and careful about reviewing my apps, with a particular eye towards safety and security, appropriate fit for the store itself, and functionality. Shoutout to @Tomasz , the feedback was thorough and fine toothed – and welcome.
Rest assured fam, Mudita isn’t sticking just anything into the store.
No offense intended, but I tried your Contacts app once – and loved the interface – but having that app named identically to the stock Mudita Contacts app made them step all over each other (system kept asking me whether I wanted to use “Contacts” or “Contacts” and kept asking me to declare a default choice on two seemingly identical, yet different apps). This forced me to do a factory reset to remove your code. This left me wary and wondering whether you did any serious QA on your apps before releasing them.
Fair – and my apologies for the trouble. You’re right to feel that way, I would be wary after that experience too.
In little wander world, it made since to just have them set up that way, I had long hidden or removed the stock apps, and had defaults already setup. One of the many things I’ve learned more about as I’ve gone from making these apps just for myself to sharing them with community is public accountability. After releasing them with that change, I received a lot of feedback and quickly renamed them and re-released.
Thanks for trying it in the first place! I’m glad you did like the app’s interface. It’s gotten a lot better since you tried it, and now it’s called Connections <3
Appreciate your work to make things right, @wander . I may very well try it again – your interfaces and screenshots are genuinely elegant – but I will probably wait until after the Mudita 2.0 update, so that I can easily uninstall anything that causes problems.
Despite winter ai is coming, mudita is the best place to be now
@urszula I’m surprised your beloved CalmCast didn’t make the cut
, although I understand davidray may be too busy to coordinate w/ mudita at the moment.
Speaking of davidray, I’d LOVE if someone picked up CalmDirectory v0.4.0 - the version before it became papermaps (cough.. @wander cough..
) - and maintained it. I don’t want a map, just a searchable phone/address book, which I feel matches the mudita vibe very well. Notably this version uses both Google Places and HERE Maps (I have mine set to HERE). Hopefully there isn’t a cost to access the data? If so, please disregard!!
Thanks to Mudita and everyone who is making Inkapps happen!
A directory without the map is now in Atlas 0.1.14: Release v0.1.14 · wanderwildwood/chizu · GitHub
Picking up CalmDirectory itself would have meant paying HERE or asking everyone for their own Google key, so this felt like the better road. What a place shows is what OpenStreetMap holds for it, and in some areas that is thinner than HERE or Google.
Thank you so much! I’m giving it a try and I fed your llamas ![]()
Glad to finally get some confirmation about this from someone on the Mudita team!
Yeah, we did reach out to @davidray & he knows how much I LOVE
CalmCast & that we want his app in InkApps. Hopefully he will find some time & add his awesome app to InkApps ![]()
