I missing a simple diary
Hi !
I wonder if it possible to get a simple diary for mudita kompakt
Should be tons of third party apps you could sideload for this.
The problem is that they are not made for mudita so the quality and funktions are really bad, but thanks for the input.
Have you looked into Simple Calendar?
Simple Mobile Tool is a group of simple, open source Android apps without ads and unnecessary permissions, with customizable colors.
Check it out & maybe it will be something that can work for you.
@urszula SimpleMobileTools apps (all their package) is not open source anymore, it was sold to a corporation. The apps include ads, and in-app purchases and tracking for sure.
The open-source project was continued by other people and it’s named Fossify
Fossify Calendar is the current variant open-source of Simple Calendar.
You can get Fossify apps in F-droid and AuroraStore (playstore).
@gezimos Thank you for the update. I was not aware of that. Good to know.
Yeah I was surprised myself when I found out. Anyway Fossify ones are being maintained everyday and have White themes that look pretty good in the Kompakt.
But in order to change the theme get them from F-droid not Aurora.
For @peter.stocker Check Fossify Notes app, it’s a paged notes app and could work as a makeshift diary app.
Thanks for the tips! I will check it out.
