I Ching review by wander
I Ching — Community App Review
Version: 0.1.4
I Ching is the Book of Changes for the Kompakt, in James Legge’s translation of 1882.
Today gives one hexagram for the day: press once to cast it, and it stays the same until midnight. Keep in the journal saves it.
Cast is for a question of your own. Write the question if you like, then cast the six lines from the bottom up, one press each, and watch the figure fill in; or cast the rest at once. Three coins by default, or the older yarrow-stalk odds, where whole lines change more often than broken ones, in Settings.
A reading shows the hexagram you cast and, if any lines are changing, the one it becomes. Below come Legge’s judgment and image, the text of each changing line, and the judgment of the hexagram it turns into. Tap either figure to open its page.
Journal keeps every reading with its date and question. Open one to read it again, add a note, or delete it, with an Undo.
All 64 lists the hexagrams in the traditional order, each with its Chinese name, pinyin and a short English name. Each page shows the two trigrams and all of Legge’s text, every line included.
Legge’s text is set in a book face, line by line, so each page is full and a paragraph runs on over the turn. Hold a word to send it to Define or Translate. Richard Wilhelm’s German text of 1924 is there too, chosen in Settings, and the default on a German phone. The journal can be exported as a JSON file and restored.
It has no internet access and asks for no permissions. The journal stays on the phone. The download is about 2.9 MB.
Source and license: GitHub - wanderwildwood/ekikyo: I Ching — the Book of Changes in James Legge's 1882 translation: a hexagram for the day, casts with coins or yarrow odds, and a journal of readings. · GitHub — GPL-3.0-only.
