I caved in and installed a browser on my Kompakt
I decided against my better judgement to to install a browser on the Kompakt, …. yes I know it goes against the whole ethos of the Mudita, but I had my reasons.
1 I still find myself carrying a smart phone in my bag, when I need to search the internet if Im away from the pc, and the temptation is always there to brows ebay, pintrest etc.
2 I recently had a rather embarrassing moment where I was stuck in a bathroom, in a remote part of the building, due to lock falling apart, I had to call the reception and get someone to release me, had I not had my second phone with a browser, to enable me to find the number, I would have probably spent the night there.
I’'ve installed einkbro, Im finding it works …… badly. which is good in my opinion, pages look pretty poor on eink screen, its pretty slow and not very responsive. All pluses really there is no way I would be doom scrolling using the Kompakt , but it is functional and is just good enough to get you out of a bathroom with a broken lock should the need arise
I think a lot of people are like you- myself included. It’s not about just mindlessly scrolling because on an eink screen it’s not much fun. I only really use it when I actually need some info.
yes the fact that the Mudita has an eink screen creates enough friction on its own, to stop the user browsing aimlessly, I would be interested if anyone knows how to change the default home screen / search engine to something other than google though.
I can relate. I had to install einkbro for several lookups and I don’t really feel like using it for anything.
Not sure about eInkBro, I only tested it once. But due to the recently mentioned vulnerability in WebView it would be wiser to avoid Chromium-based browsers.
If you want a slim, fast browser that just works, try Via Browser Official Website - A Mobile Browser that Values Speed and Simplicity
I prefer Fennec, a Firefox fork. There you can easily go to settings→search and change the search engine. In settings→home you can also change the default home page.
Worth noticing:
Sure. The most secure phone is NO PHONE :stuck_out_tongue:
Same here, for some use cases I had to install a browser. I chose the Via browser because it’s super lightweight and has useful features like QR code scan, reader mode, offline mode etc. Because of the small e-ink screen and slow processor, browsing is very annoying and is only done when really required.
Worth noticing:
So is there a browser that does not collect any data whatsoever ? I doubt it. At least not for mobile devices.
Take a look at iodé Browser.
The only good option is the Vanadium browser from GrapheneOS. All others will have security flaws.
For a browser I use twice a week to find opening hours or perform a search, I don’t really care.
All sideloaded apps are a serious risk, btw. Mudita OS K is based on the outdated Android 12 and the devs already said they only fix security issues related to the stock apps.
This only seems to work if you use the OS with the same name. I cannot find a separate download link.
This one is again based on Chromium.
Yes, Chromium browsers are more secure than Firefox browsers, see also Usage guide | GrapheneOS
You just reminded me I was going to see if there’s a way to minimize risk of getting Pegasus spyware on the phone. That’s an interesting corner case. :wink:
I have the eink bro on my HiBreak Pro (Eink Phone) and I have only used it a handful of times when I need to submit my hours for work or download a book from the internet. I literally never use it and I think it’s fine to have it on the phone unless you have severe internet addiction. I also use a launcher which hides the app from the apps that I use on a daily basis and I find not seeing it helps!
What is the vulnerability you mentioned
See this thread
Depending on who you ask, agree/disagree is 50/50. I always hear people warning against using Chromium.
I suggest to use aosmium as browser, it’s based on chromium, implements a lot of hardening from vanadium and works well when tested, better performances than gecko-based on kompakt.
Hopefully mudita will update webview, and keep it up to date so that using something eink specific like einkbro would become safe enough for most usages.
aosmium browser: GitHub - AXP-OS/app_aosmium: AOSmium - The AXP.OS browser · GitHub
