Hum — Community App Review
Version: 0.1.17
Hum is for the tune that turns up on a walk: hum or sing it into the Kompakt and it is written down as notes.
Record with the click on, and a bar of clicks counts you in and marks every beat at the tempo you set, two, three or four to the bar. With it off, sing in your own time and the tempo is worked out afterwards. Recording carries on with the screen off. Read a recording makes a take from a sound file already on the phone.
The pitch of your voice is read a hundred times a second; a scoop into a note, vibrato and a slide out all count as the one note. The key is guessed, and notes snap to it and to a grid of quarters, eighths, sixteenths or triplets. Change the key, grid or tempo and the notes are placed again from the voice.
The piano roll shows two bars at a time, with a dotted line for the pitch you actually sang. Choose a note to move, lengthen, shorten, join, split or delete it. Undo steps back through every change, and Play plays the page back. Turned sideways, the roll takes the whole width.
Send gives a MIDI file with the tempo, meter and key (in LMMS it is Project, Import), MusicXML for MuseScore, or the recording as WAV, through the share sheet or saved to a file. A backup file in Settings holds every take.
One line of melody only: chords are not read. The microphone is used only while recording, and the app has no internet permission. The pitch detection comes from Michael Moessner’s Tuner.
Source and license: GitHub - wanderwildwood/hanauta: Hum (鼻歌 hanauta) — hum or sing a tune and it is written down as notes: fix them on a piano roll, send them as MIDI or sheet music. For the Mudita Kompakt. · GitHub — GPL-3.0-only.
