I have just received the pure and I am now located in Egypt and I have some issues
- how to turn on / off flash light
- the ring tones are so low and I can’t here it
- signals is just so bad and is there a way to force the use of 2g network?
thanks
where in settings I can find 2g only ?
@Amr_Osman Make sure you update your Mudita Pure to the newest OS version, which is 1.2.1. There were a number of audio fixes that were implemented in the last update. A new update is coming shortly.
is there an option to force the use of 3g or 2g only as 4g signal in my area is weak
@Amr_Osman I reached out to the team about this & currently there is no possibility to switch manually between 2G, 3G or 4G. However, our team is looking at possibly implementing this in the software. We think it’s a good idea.
