How To Remove InkApps / KalmLauncher
A lot of users on the forum seem to be looking for ways to strip down the device and limit customization after the 2.0 upgrade. If you’re willing to use the command line and adb commands, you can remove / disable the InkApps app store and the Kalm Launcher. The apps will technically still be present on the phone, but they will be inaccessible without connecting to a computer and reversing the commands or factory resetting the device. These commands will likely need to be repeated after a system upgrade. You’ll need to first enable developer options and USB debugging and install Android Debug Bridge (adb)  |  Android Studio  |  Android Developers.
To remove InkApps and KalmLauncher:
adb shell cmd package uninstall -k --user 0 com.mudita.inkapps
adb shell cmd package uninstall -k --user 0 com.mudita.launcher2
To restore them:
adb shell pm install-existing com.mudita.inkapps
adb shell pm install-existing com.mudita.launcher2
