How to choose/change mobile network
I am on vacation and want to change my mobile network but can’t seem to find this in settings
@john765 Are you asking about being able to choose which network provider you connect to while roaming?
I want to change my mobile operator. But I don’t have this options. How can i acces this? I don’t have manual or auto mobile networks selection.
@john765 If you’re abroad- from what I know (this is how it works in the EU)- your home carrier has commercial agreements with specific foreign networks. These agreements define which local carriers your SIM is allowed or prioritized to connect to when you’re abroad.
Your SIM card (network provider) has a preferred roaming list, which ranks foreign networks based on:
  • Signal quality
  • Agreement priority
  • Cost efficiency for the home provider
Kompakt uses this list to decide which network to connect to automatically.
I am close to border from non EU country. And my phone chooses this network. So i am in non EU roaming. And must pay for all. So this is a must have option. Even the most basic phones have this option. Pleas add this.
Can i access it anyhow , via Activity manager or somehow?
@john765 So, let me see if I understand this correctly- Your home SIM network is automatically switching to another network (not the one that you have on your SIM) because you are close to the border of different countries?
Yes. It switches to non EU network. Probably because it has stronger reception. That is always the case here where I am. Before i would just manually change network to a wanted one and problem solved. Here I can’t find this option.
@john765 Got it! Let me ask the team how to get around this.
Great. And this option should be available in settings as it is basic and necessary
Any news on this. I am stuck at wrong network. Can’t make calls or go online because it is too expensive.
UPDATE: Our Team is aware of this and they will be adding a manual setting in a future update.
Thanks. They should simply return stock android network settings. Manual and auto network selection etc…
@john765 They are going to be adding this. I actually had this happen to me when I was traveling.
Please ask for mobile data and location toggle in quick settings also. That is crucial for better user friendly experience.
@john765 You mean here?
Yes. Or instead of weather widget. The weather widget should be optional as it drains the battery and uses data.
@john765 Got it :slight_smile:
Hi,
Back on June 2nd, Urszula wrote on the forum that developers were already working on manual mobile network selection and that it would be included in an upcoming update. A recent update arrived, but nothing has changed — the option is still missing.
I live close to a border, and this creates huge problems: my Kompakt constantly switches from my home operator to an operator in the neighboring country, forcing me into roaming against my will. This is a basic feature that has been available on even the cheapest phones for decades, and it’s surprising that Kompakt still doesn’t have it.
Please give a clear answer: when exactly will this feature be implemented? Without manual network selection, the phone is practically unusable in border regions.
Thanks.
Now the weather is bad and the phone is constantly in roaming. I’m shocked. It’s impossible to use.
@victorpure This feature is scheduled to come in the update at the end of this month (Sept). Our apologies for this delay, but I’d like to assure you that it’s coming.
