Isn’t there anyway to secure that you don’t have to go to the battery manager once a week to unrestrict sideloaded apps?
Can you please elaborate a little more on what is happening in your case. I’m not sure I understand. I have sideloaded apps- several of them, in fact, and I don’t do anything with battery manager & they are not restricted in any way. Can you be more specific which sideloaded apps you having issues with and what is happening?
I have sideloaded drlyd a danish radio app, Radioeins a german radio app and spotify from Aurora Store. When I listen to the apps, the battery manager shuts down the apps everytime 20 minutes has passed. But when I go to battery manager in developer options, I can remove apps fra restrictions and they will not shut down.
But…the problem is, that I have to remove retrictions at least once a week, when I use the mentioned apps to listen to podcasts or music
Are you going to battery Manager or at Duraspeed?
Go to Developer Options > Search for “Duraspeed”
Open Duraspeed (the MTK battery management utility), and disable it (turn the toggle to OFF)
Thank you. Have done that.
