Harmony 2 meditation sound
Hi there,
I’m not sure if this is on a new update, but would it be possible to implement sound during meditation? I was really hoping to use one of the ambient (like ocean waves or birds chirping) or colored sounds (such as brown) during my entire meditation. Is there any way to do this – if not could it be something to add?
@muxbree Thank you for reaching out. Let me see if I understand your request correctly:
You would like the ability to upload CUSTOM audio sounds to the Meditation Timer, so that you will her your chosen sound at the end of the session- instead of the the standard sound?
Yes! Although, for mine, there is no sound at all. Is there a way to play a sound for meditation? Also, it would be cool to choose one of the alarms for meditation, too.
@muxbree You probably have the volume set to very low. There’s definitely a gong sounds at the end of the meditation session.
Oh, I heard that. I meant during the entire meditation time. It would be cool to listen to either our own added sound or to the babbling brook. I guess I could just use the relaxation, but I also like the gong sound too
@muxbree I will pass your suggestions to our team.
This would be suitable for meditation timers on Harmony and Pure too. Calming sounds do get along with meditation.
Hopefully this can still be implemented! Just updated the list in the other thread :slight_smile: it includes this
Has this been updated? I dont see choice other then nice factory defaults in settings - meditation?
Nope. Urszula said she passed the suggestion to the team, but no updates. Maybe you can ask her?
Hi guys, regarding the suggestion about adding sounds to meditation sessions, there is no decision yet from our team. The suggestion has been passed on and the tech team has to decide if it’s a feasible feature and if it can be added. Unfortunately, as of today, there has not been a decision yet.
No problem! We appreciate you sending it on and hearing the update. All good. Thank you, Urszula! :blush:
