Handset — Community App Review
Version: 0.1.22
Handset is a phone app: Favorites, Recents, Contacts, a keypad, and the call screen, laid out like the Kompakt’s own and drawn in Mudita Mindful Design.
Nothing in a list calls. A press on a recent call or a contact opens their page, and the call is made from Call there. Every number in Recents gets its name, however it was saved.
A call coming in shows over the lock screen. Answer and Decline are held down, not tapped, so a phone coming out of a pocket does not answer itself, and while it rings a covered proximity sensor ignores every touch.
Blocking is in Settings, and all of it is off until you turn it on:
- numbers not in Contacts, and hidden numbers, can each ring, be silenced, or be declined
- favorites, numbers you have called, and someone calling twice within three minutes can always ring
- a block list of whole numbers and starts of numbers, like 555*, kept in Fossify’s file format
- Blocked calls, in Recents’ menu, lists what was turned away and why
Also: missed-call and voicemail notifications, hold 1 for voicemail, speed dial on 2 to 9, favorites ringing through Do Not Disturb, a ringtone for unknown callers, and delete or clear Recents. Contact opens the person’s card in Connections, and Message opens your messaging app.
On becoming the phone app it asks once to switch Handset on in DuraSpeed, so calls are not missed after the screen has been dark a while.
It began as a fork of Fossify Phone, has no internet permission, and keeps nothing off the phone.
Source and license: GitHub - wanderwildwood/itodenwa: Handset (糸電話 itodenwa) — Favorites, Recents, Contacts and a keypad. Nothing in a list dials on a touch, a call is answered by holding the button, and unknown numbers can be turned away. · GitHub — GPL-3.0-only.
