Flashlight/Customizable buttons
Please, please add the ability to double click the power button or long press for the torch to turn on! Customizable buttons are great, but at least the flashlight please.
Honestly, if I had one request, this would be it for me. I want to be able to turn the torch on without having to go through the lockscreen → menu screen → flashlight process. A quick button press and the light comes on would be fantastic! Double press on the power button works on my pixel and it’s so helpful.
Welcome to the Mudita Forum. We’re glad that you’re here. Thank you for the feedback. I will make sure to pass this to our team. I can’t promise anything, but I will definitely let them know that you’d like to see this in Mudita Kompakt.
Very good idea
Same! It’s one of the reasons I was considering the Light phone 3. It’s even got a lil dial for brightness! I have a dozen headlamps around the apartment but still end up using my phone half the time to find stuff. A button would be great for the users who opt to leave the display light off. I’d have the display on but it’s a white light, not warm, so messes with the eyes.
For anyone who’d like this now: Glance, my lock-screen app, can do it. Turn on Power pressed twice under Torch in its settings, and two quick presses of the power button switch the torch on or off, locked or not.
It’s the white light, not the warm one. Mudita keeps the warm light for its own apps, so no other app can reach it. The control panel also won’t show it as on, so while it’s lit the lock screen says “Torch on”, and pressing that turns it off.
If you use fingerprint unlock, press with a finger that isn’t enrolled, or the phone will unlock instead.
If I were to install Glance just for this one feature, would the app have a significant impact on battery drain?
On my Kompakt over the last three days, Android counts about 3 mAh to Glance, around 0.1% of one charge, with the whole panel on. It has no timers and doesn’t use the network. You do switch it on once in Accessibility settings.
