Happy with MuditaOS K 2.0, but sharing Kompakt’s connection takes too many steps. I can turn on the hotspot from the Control Center hotspot icon or via Settings → Network and Internet → Hotspot and Tethering → Wi-Fi Hotspot, but tethered devices only get internet if mobile data was already enabled. Since there’s no data toggle in the Control Center, I first have to enable it manually under Mobile Network every time.
Suggestion: when tethering (hotspot, USB, or Bluetooth) is turned on, automatically enable mobile data, and switch it back off when tethering ends — ideally as an optional setting for users who prefer manual control.
Thank you for this feedback. I will pass it on to the team. However, please keep in mind that automatically enabling mobile data every time tethering starts would also turn it on for someone who only meant to share Wi‑Fi. If someone intentionally turned off mobile data because they are abroad & roaming is enabled and the phone automatically enables it & uses cellular data, that could lead to charges.
If Kompakt is connected to Wi‑Fi, it can share that connection through its hotspot while mobile data stays off.
Perhaps, a mobile data toggle in Control Center would solve the extra-steps problem you’re describing while letting people decide when to turn mobile data on.
Thank you for the clarification. I agree that automatically enabling mobile data by default could lead to unintended data usage, especially for users who are roaming.
I think a Mobile Data toggle in Control Center would be a great solution to reduce the extra steps while keeping users in control.
As an additional option, I would suggest introducing an opt-in setting to automatically enable mobile data when tethering starts, disabled by default to avoid unexpected data usage.
I hope these suggestions will be considered by the UI, UX, and CX teams for future enhancements.
