Feature Request: Auto-Generated Letter Icons for Sideloaded Apps
Hello,
I’ll be direct, as the team already has many topics to go through.
First of all, the Kompakt is awesome, thank you for that.
For a future update, it would be great if, instead of using the current default icons for sideloaded apps (which can look a bit creepy at times), the system could generate a simple icon featuring the first letter of each app’s name.
This would help maintain visual harmony across all apps and prevent odd-looking icons from standing out among the great default ones.
Ideally, this feature could be toggled on or off in Mudita Center, next to the corresponding APK in the app list.
Thanks for your time,
fmrccc.
@fmrccc Thank you for all these ideas :slight_smile: I will pass it on to the team.
