Feature Idea: Multiple Alarms on Mudita Harmony
Hey Mudita community!
We have been loving our Mudita Harmony. Just one thing, me and my partner have different work schedules. (I get up at 9, he gets up at 5) and I am always worried if he will forget to reset the alarm in the morning. The ability to set two separate alarms would be so helpful for us!! Any chance that’s a work in the process?
Thanks!
Maddi
Hello @sanehome thank you for your post! I believe someone has already mentioned the need for two separate alarms. We always note all suggestions to our products and we review them in our Design Team. Thank you for mentioning it, it’s a feedback for us it’s an important feature and we should take a closer look into it. We do have a backlog of new functions and features to implement so we won’t be able to just add it to the nearest release but we’ll try to give it a higher priority :relaxed: Once again, thank you for sharing your thoughts and ideas, glad you like your Mudita Harmony!
Hi! I really like the alarm clocks.
I wanted to ask whether it’s now possible to set up more than one alarm time. Me and my girlfriend need to get up for work at different times - something which I guess is pretty common - so it would be great if the alarm could be automatically set to ring at two different times.
Is it possible now with the 2.0 Harmony or 2.0 Bell, please?
@cajhi Thanks for reaching out. Your question is very valid & our community has asked about this previously. Currently, it’s only possible to add one alarm, which we do understand, complicates things when the alarm clock is shared by more than one person. However, we have passed this on to our team & we’re checking if this is something which we can implement in a future update.
Hi @urszula, many thanks for the reply. If you hear back from your colleagues, would you please let us know here what is the view on this, internally?
If this is possible to implement, and you would be looking to do it, I would be happy to buy the clock and wait for a future update.
But a similar note has been shared here in April 2022 by @aleksandra (‘we will try to prioritize this’), but since then it has not happened, even though it has been a year and a half.
It would be great to understand whether this is something which you would find possible / desirable to implement in one of the upcoming updates, or if it is not realistic to expect this within, say, the next 1-3 months.
Many thanks!
Hi, any updates on this / likelihood it could be implemented in a foreseeable future, please?
@cajhi I will reach out to our team about a possible time frame on this feature & get back to you.
Hello,
i’m writing here to show my interest into this multiple alarm feature.
I know that your OS is open source and i wanted to know if it is possible to try to develop this feature by my own.
thank you
Thanks Urszula, let us know how’s it looking, please
@cajhi I did talk to our team, but unfortunately, currently we do not have this on the roadmap of new features. The reason for this is some hardware and software limitations that maybe difficult to overcome when it comes to implementing a multiple alarm function on Mudita Harmony.
If anything changes, I will be sure to post on the forum.
Hi, thanks for the update. It’s a shame, I really like the idea and the design but at the same time I really struggle to justify paying 200 euros for a digital alarm clock which doesn’t support a basic feature like setting up more than one alarm, that’s absurd.
@cajhi Yeah, this feature would definitely be great.
However, if you think about it, the way Mudita Harmony hardware currently works to activate & de-activate the alarm (By pressing on the big top button/knob), it would be nearly impossible to incorporate a second alarm into the equation. If person A gets up at 6:30am & person B get’s up at 8:30am, then there would have to be a separate mechanism to keep that alarm activated while turning off the first alarm. It’s more of a hardware issue at the moment.
@urzula. I was also really hoping for this feature to be added, and I agree its very disappointing at this price point to not have at least two alarm options.
I know your team has thought this through well, and there may be other reasons for not implementing, but could you just require the top knob to be reactivated after the first alarm is de-activated?
ie: You created an “Alarm 1” and an “Alarm 2” menu in the main menu. Each with the current alarm settings options, but also add an option to have that alarm ON or OFF (will be activated/de-activated by the top knob, or wont be activated/de-activated by the top knob). Then when the top knob is hard pressed (showing red) it would activate any alarm that is ON in its settings. When the person using the first alarm hard presses the top knob, it would de-activate both Alarm 1 and Alarm 2 (the problem you outlined). BUT, if the person using the first alarm hard presses the top knob again, both Alarm 1 and Alarm 2 are activated and Alarm 2 will go off next. The person using Alarm 2 then hard presses the top knob to de-activate Alarm 2, and simultaneously de-activates Alarm 1 until the top knob is hard pressed to activate any alarms that are ON for the next day.
This leaves the responsibility of making sure Alarm 2 is active on the person using Alarm 1, and may cause some arguments, but still sounds way better than not having the Alarm 2 option at all.
@trv Thank you for reaching with your ideas. We really appreciate it. I will p definitely pass them to our team and what they think about this solution.
While I am sure small team is devoted to new products this year, this multi alarm setting would be helpful. I am looking to buy the same device first.
Having the same problem (partner with different time schedule) would love to see this feature implemented first.
On HW problem - hardware press would null first alarm, passing the off feature again to second. This is I suppose possible in software/OS.
Surely takes some time and thinking, but since its growing demand related to already mature product, hope could be on the radar.
Addendum: IS the same case for Harmony 2 or is this just older model quirk?
Thanks.
@anon11367638 It’s for both models. The way the hardware operates is the same in both models.
Thanks for the ideas. I will definitely talk to the team about it.
I just wanted to say, I really like the creativity & problem-solving you thought of to go around the hardware issues. I feel like if this was at all possible to implement, this would be so much better than having no option for 2 alarms. I’d even be willing to take a vote to see if this is something that the majority of the community agrees with or not.
Another possible idea-- and I don’t know how this relates to hardware, but, if they somehow were able to code in ability to select different days of the week, then a user could set certain 2 alarms on different days, but use your exact method every single day. So basically, nothing would change in terms of what you said, just that you could set alarms for different days and they will only be active once you hard press the knob to activate both alarms for the day. And go through the process you described to deactivate & reactivate…I was just adding onto ability to set multiple alarms on different days and using your methods to actually activate them every day! I hope that made sense.
Edit: I just wanted to point out, I realize a lot of the energy and resources expended will go towards the Kompakt since it’s not even out yet and once it is, users will want a lot of additions to the phone. I’m well aware that the Harmony 2 will not be priority. However, if something like the suggestion made earlier could be implemented, not only would it save money from making a whole new clock and keep old clocks from either being dumped, sent back or collecting dust, but it will also be beneficial to both current and new customers of the Harmony 2. The appeal will make it more attractive to buy and maybe those who go with their Kompakt will want to get the Harmony 2 after reaping the benefits of their new phone.
TL;DR: I think putting more time to see if this is possible would not only benefit current users of the Harmony 2 but will be an attractive addition for new future users to purchase the clock as well. It seems like a good investment to me. But I do understand it isn’t #1 compared to the Kompakt.
@ donitan Here is the suggestion! Mudita hasn’t replied back if they’ve tried this yet. This seemed like something that could possible work, but no way to know until Mudita has tested it.
P.S. look at who I replied to. They suggested it above!
