Review updated by @wander
- Version:
0.1.8→0.1.9- Checksum:
a653e2bc1579fe6387e6eb95be71ed597fb116fc0d6ce11e16ea542a42f1211d→ad4cf376d21c252ac670f98dd3cb30c7cc2596dd61c9e6d893204e9246737325
- Version:
0.1.9→0.1.10- Checksum:
ad4cf376d21c252ac670f98dd3cb30c7cc2596dd61c9e6d893204e9246737325→66861a45ebb5d2a555c80cc38fcd41d94d05443737251427569cb1e1e4d8f06f
- Version:
0.1.10→0.1.11- Checksum:
66861a45ebb5d2a555c80cc38fcd41d94d05443737251427569cb1e1e4d8f06f→c4fc115d2bf792ce3844ebbb5199c0aa50ae91b765bdc0e2dc518c6700096b04
Review for version 0.1.11
User rating: ★★★★★
I really like this app. It’s smooth, clean, and works perfectly with my Gmail.
User rating: ★★★★★
Can you please help how did you get this working? I tried, but there is always error to setup.
User rating: ★★★★★
Checking incoming server settings failed
Server error
The server returned the following message: Application-specific password required: https://support.google.com/accounts/answer/185833(Failure)
User rating: ★★★★★
Hello, sure.
Step 1: Get a Google App Password
You need an App Password from Google:
Go to your Google Account settings: myaccount.google.com/apppasswords (Note: 2-Step Verification must be enabled on your Google account).
Type any app name (e.g., Mudita Phone) and click Create.
Google will generate a 16-letter password. Save this code—you will use it in place of your normal Gmail password.
Step 2: Incoming Mail Server Settings (IMAP) - In APP
Protocol: IMAP
Server: imap.gmail.com (make sure to type imap. before .gmail.com)
Security: SSL/TLS
Port: 993
Authentication: Normal password (or Plain password)
Username: Your full Gmail address (e.g., [email protected])
Password: Enter the 16-letter App Password generated in Step 1.
Click Next.
Step 3: Outgoing Mail Server Settings (SMTP)
Server: smtp.gmail.com
Security: SSL/TLS
Port: 465
Password: Enter the same 16-letter App Password from Step 1.
Click Next to finish, and everything should work smoothly after that ![]()
User rating: ★★★★★
thank you @Denis for detailed steps.
@Denis Thanks for helping ![]()
@ramamohan glad you got it working!
User rating: ★★★★★
This is an awesome app. Just one feedback in terms of the UI, I’d recommend making the sidebar just appear instead of it sliding when you open it. It’s not the most ideal for eink.
Thanks for setting this up!
@stephane Thanks, that was a good call. In 0.1.14 the side menu just appears and disappears, with no slide, however you open or close it, and the folder rows stay still too. It’s on the card here and on the release page, Release 0.1.14 · wanderwildwood/tayori · GitHub, or through Obtainium as usual.
- Version:
0.1.11→0.1.14- Checksum:
c4fc115d2bf792ce3844ebbb5199c0aa50ae91b765bdc0e2dc518c6700096b04→093bc88cd32a38a450413713adce7b7169ff2a200aa539ff1ab675ec7a89c19b
- Version:
0.1.14→0.1.15- Checksum:
093bc88cd32a38a450413713adce7b7169ff2a200aa539ff1ab675ec7a89c19b→2073c1db4a63e8d9b0317776c33f76acc2be4d0495c7d846216efdeaaef27a07
Review for version 0.1.15
User rating: ★★★★☆
This is great - email is the only other app I needed on the Kompakt.
The only problem I’ve found is that if I create a new email and try to add an image by opening the camera, the (email) app crashes. I’m guessing it might be a permissions problem but can’t see where to allow the permission.
- Version:
0.1.15→0.1.17- Checksum:
2073c1db4a63e8d9b0317776c33f76acc2be4d0495c7d846216efdeaaef27a07→b44e2218c6609d340f2e573409060dbe91508993db5850c7863a839557218a26
Review for version 0.1.17
@mupeter thanks for the report. It wasn’t a permission problem: the Kompakt’s own camera doesn’t take photos for other apps, so Email found nothing to open and closed.
Version 0.1.17 fixes it. Open camera now uses any installed camera app that can take a photo for another app (for example Camera). If there isn’t one, it says so and points you to Attach file instead of crashing.
User rating: ★★★★☆
Wow! Thank you - that works fine. now. Great service.. looks like I need to go and feed the llamas ![]()
