Downloaded Maps
Are there any plans in a future update to add more data to the maps? The maps in the US are kind of limited. When I search for any location by its address it wont show. Businesses I can search for by name to bring up, but by its address it wont. This makes it difficult for finding someone’s home since the on ly way is by their address. Also, it would be great if we could search for a business name and then look on the map itself at all options for that business to know I’m selecting the right one. as an example if I search for BP gas stations that I then could look at the map and see all the BP gas stations so I can tap the one I want. these features would make the gps app so much more functional and would be great if they were implemented.
@joshua-h Hi. Thank you for reaching out. I’ve notified our team about this, but on my end things look OK.
I’m able to find specific addresses & BP Gas Stations around where my parents live.
I can also find restaurants by name.
Just to make sure, you’ve downloaded the region that you’re searching for?
I appreciate the response. I tried again with my parents address in Pennsylvania and it still doesn’t show as an option. their street shows up but not their house to know where it is on the street. Not really a problem with my parents house but thinking for future new addresses. I double checked and do have the Pennsylvania map downloaded.
@joshua-h Can you try other addresses? They maybe getting cut off.
I just tried another place (my favorite hot dog joint) in Chicago, and I noticed that the numer part of the address is getting cut off. Is this what’s happening to you?
So I’ve tried some more and some addresses it will list the full thing including number, others it can find the road but not the specific building or house. Also is there a plan to allow typing in the name of an establishment when it brings the list of options I can switch to a map view and see all those options from the list marked on the map that way i can easily select the right one? For example if i search Walmart and the list of Walmarts in the area pop up in a list then i could select a map view and see that same list of Walmarts shown on the map all at the same time so i can quickly pick the one I want.
