Hi,
I have an older laptop - I have tried to cut down on the upgrade treadmill and its specs are more than enough for my needs.
It does not have an USB-C port. Would I be able to connect the Mudita Pure to it using an adaptor?
Thanks,
Hi,
Thanks,
Only the connection on the Pure is USB-C. If you use the supplied cable, you can connect the Pure to any laptop with a standard USB port.
