Hello,
I’m based in the U.K. and backed the Mudita Pure phone when it went live.
I noticed in the FAQ section, under the “Carrier…” question it states the phone will be compatible with “AT&T, Verizon, T-Mobile and Sprint”. My question is I use another provider, O2, and was wondering if I this will or will not be compatible with the Pure phone?
I don’t really want to sign up with another provider if possible and I want to make sure I can use the phone.
Thank you,
Hi @cosmicfish1000, Mudita Pure should work with O2.
I’m also based in the UK so I had the same concern!
Hi Tiffany,
Okay, that’s good to hear thank you:)
