Can AirPods connect to Android?
@robertzamora52 Thanks for your questions. Using APPLE products outside of the APPLE ecosystem is always tricky. It’s a proprietary system that doesn’t really play well with other devices. You might be able to connect, but all features are not guaranteed & the sound may not be what you’re used to if you’re using them in an APPLE ecosystem.
