CalmApps maybe becoming PaperApps
Just got back from 2000 miles of road using PaperMaps, and it worked really well! I noted down just 5 things I’d change.
  1. Since this is a long road trip a lot of stops were planned ahead of time, meaning I didn’t actually need the places directory. Maybe a toggle in the app to turn off Google API requests, if you just want to navigate to specific addresses?
  2. Remembering the state of voice navigation. If I mute it in one navigation it should start muted in the next (at least that’s my preference)
  3. I should be able to change the center of the search radius per-search, instead of only in the default settings. That way I can find something at my destination rather than the closest option.
  4. If my current location can’t be determined using GPS, allow specifying a start location based on an address, helpful for finding mileage.
  5. Also helpful for finding mileage, show the mileage on the route overview screen, so you don’t have to start the drive to see the total mileage.
Just some things I noticed, nothing made the app unusable or unpleasant. Overall it was a smooth and reliable experience. Thank you!
You’re so right about this. I love this app. It’s my favorite.
If you do decide to change it, I have a feature request:
Hitting the back of forward buttons on my headphones should skip back or forward in the episode. Also, it would be great if there was an option to choose a diferent time-interval for forward skips an backward skips.
And I might have found a bug, but it could be intentional: finishing an episode doesn’t delete it.
I still love the app and will keeping using it regardless of whether you update it or not. In my opinion, the UI is great as is.
By the way, I do like the PaperApps UI for the PaperTunes app, I don’t agree with the other poster that it is confusing.
I’d prefer it if you could keep CalmDirectory as a separate app, and maybe Paper Maps as another.
This whole “Calm”/”Paper” thing is getting confusing. Maybe as a bonus you could create an app called CalmPaper :stuck_out_tongue:
CalmCast is perfect - a daily driver. Love love love it as is. Thank you :grinning_face_with_smiling_eyes: :folded_hands:
I feel the same way. I’m hoping that as the new PaperApps roll out, the CalmApps still stick around. I tried switching from CalmMusic to PaperTunes and ended up switching back. The PaperApps UI feels unnecessarily complex and distracting, having the next screen to the right always peeking out of the margin, and it makes the usable width of the current page even less than it is already. I really don’t want to switch to the PaperApps but I love the CalmApps and don’t want to lose the functionality.
Agreed. I switched to Wander’s fork of CalmMusic - Music Box, and love it! I can appreciate the paper UI asthetic, but it’s not for me.
Same here. I would love to see the Calm-series being maintained, as I much prefer the design. Although, the new PaperTunes seems to have a much better library then Calmmusic or Music Box (e.g. albums often lack many songs, artists are named differently and are not aggregated properly)
Hi David, I would love to have the football scores app PaperScores, are you considering releasing it?
Regards
Sean
Would just like to say I’ve been using PaperMaps for a bit now and so far I’m really liking it! I’m still not in love with the menu UI but the map functionality has been pretty good. I’ve really been struggling to find a maps app for the Kompakt that suits my needs, Waze functioned excellently but wasn’t private enough for my tastes, while Organic Maps was more private but I could never get the voice directions to work. PaperMaps seems to fulfill both needs nicely. The one issue I’ve been having is that it just can’t find some addresses I plug into it, but I assume that’s due to the data source it has to pull from.
I had been using PaperMaps for a while and for the most part things have been good, with an occasional “Location Not Found” issue. But yesterday I noticed that the app seems to not be connecting to the internet. The map doesn’t load and under the recommendation sections there is only “No results found for…” I tried closing and restarting the app as well as completely re-installing it and the problem persists. I wanted to check in if the app is no longer being supported before I continue to work on seeing if something is wrong on my end.
There was a billing issue in Google Places on my end. I had a bad card on file. This should be working again.
BUT, with that said, I was a bit surprised by the bill this past month. If it’s trending high again this month I will have to look into a solution. I’m trying REALLY hard to keep these apps free for the user but if the usage is high because of traffic, there’s not much I can do. I’m going to look into my api usage and make sure it’s not something I’m doing that could be more efficient.
I’ll keep ya’ll updated the best I can.
