Calls and notification volume and sounds
Volume
How do you experience the volume for incoming calls and notifications on Kompakt?
If I have the volume set to the lowest, I still think it’s loud. Maybe the ringer settings need some more adjustment? I’ve never needed to have the ringer set above halfway.
Sounds and ringtones
I would really like to have more shorter sounds to choose from, especially when it comes to notifications. I have the shortest one now (Koshi 2) but a few more would be nice. And for calls, I’d like to have more options as well. I don’t like guitar or country music. :smiley: But this can maybe be solved with customized ringtones that some have been talking about.
@denguefeber Sound is such a subjective thing to measure. For me, personally, the loudspeaker for audio (podcasts, songs, long-form narrated articles) is a bit too loud on MAX volume. I listen at 70-75% volume. I don’t like loud notifications for messages so, I have it set the notification sound to DRUM- it’s perfect for me.
Yeah the drum is my fav for text notifications, its not loud so I won’t be able to hear it when the phone is on since we can’t shut off call sounds and notification sounds separately, I am glad you guys used the same sounds, will always have a part of the Mudita Pure with me at all times now lol
I agree with you, @urszula that whether one appreciates a certain sound is subjective. Considering that it is subjective, it’s somewhat amusing that the majority of the sounds are country tunes with guitar. :slight_smile: Regarding the volume, I believe one can be more objective and adjust the ringer steps for volume better. IMO the lowest volume is still high, and the highest is very high. :slight_smile: I also wonder if it’s just me who experiences it this way. I’m talking about incoming calls and notifications.
Anybody having problems with incoming call notifications? For some reason my Kompakt just doesn’t ring anymore.
Obvious question, but if you open the Quick Settings screen (third hardware button at the bottom of the screen), make sure you haven’t accidentally pressed the loudspeaker button (which is ecffectively a mute button). I’m talking about the icon in the square above the volume bar, next to the brightness bar. If.that doesn’t solve it, have you tried restarting?
Edit:typos
That’s quite odd. The the calls & messages still coming through- like it shows that you missed a call or a message, but you never heard it ring?
Exactly. Sometimes I happen to look at the screen while the call is incoming, and I only see a phone symbol in the top tab, but not on the whole screen, and it doesnt ring. Its been like that for three weeks, all the time.
