Bluetooth Issue
I have a Beats Flex headset, and have connected to the Kompakt previously. I ended up connecting to another device for a day, and now do not have the option to reconnect to the Kompakt. Despite resetting the headset, it now does not make an appearance on the Bluetooth “searching” menu.
The Beats Flex headset still connect to the other phone without issue and is discoverable on my laptop too.
Any way to get the Kompakt to recognize and previously connected headset? Nothing is working for me.
This is a bug that was missed on last update. You have these solutions:
  1. You need a third party app like a “bluetooth widget” that will scan and show the Bluetooth devices previously connected to your device.
  2. You can try and install Beats app, if it works without GooglePlay it should allow you to reconnect to them.
  3. In case you’re using my launcher inkOS, in yesterdays v0.2 update I have added a setting that will allow you to reconnect
  1. Wait until the end of this month when the next update should come and hopefully it gets fixed properly this time
See my solution posted here:
Same issue here. Kompakt recognises both vehicles every time but not my AirPods Pro at all since recharging them.
I don’t want to have to use third party solutions as this should be a priority 1 fix for the team. I’ve spent more time today trying to remedy this than using my kompakt all weekend since it arrived, completely missing the point of it.
Any update from the team for fixing this in the September update?
