Bikey review by alexV
Bikey — Community App Review
Version: 1.0.0
Bikey is a lightweight bike computer built specifically for e-ink devices. No animations, no wasted redraws. Just the numbers you need while riding, designed to be easy on your battery and easy on your eyes in daylight.
Features:
  • Live ride metrics: current speed, average speed, distance, elapsed time, elevation gain, and calories burned, all updated from GPS and barometric altitude in real time
  • Pause / resume / stop controls, with a confirmation prompt before ending a ride so you don’t lose data by accident
  • Ride history: every completed ride is saved with date, distance, average speed, duration, and calories burned, viewable (and deletable) from Settings
  • Personal settings: set your body weight for accurate calorie estimates, and switch between metric (km, km/h, kg) and imperial (mi, mph, lbs) units
  • Built for e-ink: a simple, high-contrast, low-refresh interface that avoids the visual noise and battery drain of a typical fitness app
