Battery in pure is not insufficient
@piotrek71 Thank you for reaching out. I will ask them to get back to you as soon as possible.
@piotrek71 I was informed that they did send you an email asking you to confirm your address. Did you not get this email?
Tak otrzymałem. Bardzo dziękuję za poinformowanie. Pozdrawiam i czekam na rozwiązanie mojego problemu.
Już tydzień @urszula jak odesłałem telefon z powodu wady baterii i dodatkowo wyświetlacza. I do dziś żadnej odpowiedzi. Jak mam się dowiedzieć co dalej nawet maila nie dostałem czy telefon dotarł. Coś słowo Mudita i działanie działu wsparcia nie idą że sobą w parze. Przykre to :frowning:
@piotrek71 Bardzo przepraszamy, że tak długo pan czeka na odpowiedź. Zaraz to zgłaszam i wyjaśniam.
There is a Polish Speaking thread, please use English only in main ones :slight_smile:
Ok i will try to do it :wink:
After almost two week i had taken a new pure. Previusly model having problem with battery what was i think, but new have the same problem. Problem is the battery itself. Still working only two days. What is wrong in the Pure battery is?
Yes. Music player drains the battery quick in Mudita Pure. Player is not optimized for sure.
For just phone calls and messages, my device gives 4 full days of battery life.
Mine lasts about 5-6 days. I think that’s a bit too short because in the beginning, I remember reading that it would be like a week at least. I wonder what impacts battery drain in Mudita Pure? I mean those apps aren’t really that high-powered.
I can get mine to last about 5 days with regular use. Kinda disappointed it can’t go a whole week.
Sad but true. Thanks for this document. How can we stop this terribles , how can we help this people.
For me it is almost 5 days.
I use following settings on my Mudita Pure:
  1. Display light: Frontlight ON, Automatic OFF, Brightness 2 bars.
  2. Bluetooth: OFF. I just turn it on when needed.
  3. Keypad light: OFF.
Having the Frontlight OFF probably would further reduce the battery drain. I keep ON as it feels beneficial for me. Aside that, I wonder if Dark mode (Beta) makes a difference here.
@sv3np I’ve actually got it to last 7 days. However, I think it’s because at least once per day, I plug it into Mudita Center to reply to/send some longer texts. I know plugging it charges my Pure & even if the connection is less than 5min, I believe it does make a difference.
Has the battery life improved with all of these updates?
This is actually something I have been pretty passionate about for quite a long time. Not only is battery mining bad, but the ewaste issue compounds this problem. LiFePo batteries are better than lithium ion in almost every way, but these have yet to catch on outside of a handful of products. Hopefully things will change over the coming years.
@kirkmahoneyphd Looks like YoutTube took down this video…
I wonder why? Hmmmmm
Some of it claim that battery drain was improved. I wouldn`t tell since I ll start using the phone with latest firmware. Unoptimized mp3 player is a bit concern since I do plan to use it for music listening :frowning:
I understand that with many options off, a bit of using Center and use just for call it can least 4 to 7 days but I wonder about other way around: I need strong backlight due to eye condition so, what about everything on max and up to 5 hours a day music use?
Standing 2 days would be great, I dont mind charging every other day, since Smartphones needs restrictive use to do that.
Also has anyone found manufacturer source of exact batteries?
I would love to charge two batteries and carry one with myself as backup, but Mudita stopped selling it seems since EU changed battery restrictions to next to TNT.
