Me too, usually from 20 to 80, and it still takes 90 minutes. It seems that all those batteries are different. Some last 5 days, some not even 1 day.
Mine still only lasts about a day (I think due to all the apps I have), I’m just able to charge it fairly quickly, at least in my car.
DURASPEED is enabled - but explicitly disabled for Signal and WhatsApp. This is the major power drawing factor.
The reason for doing this, was that otherwise I would only receive e.g. a WhatsApp message when I actually open the WhatsApp app.
When someone sent me a message and DURASPEED stopped the app I would not be notified.
@richardkrikler Thanks for the clarification. What you wrote makes a lot of sense.
I’ve been noticing my battery draining too, so I did some investigating. @richardkrikler thank you for sending me down the rabbit hole of working with claude + adb. I’ve learned a lot and the capabilities are pretty amazing.
My setup: Kompakt on MuditaOS K 1.6.1, US Mobile (AT&T network), a handful of sideloaded apps.
With the screen off my phone drained about 2% an hour (around 55 mA), so roughly two days per charge.
What I tested:
- Apps: wander’s messaging app with Signal linked was waking the phone about every 2 minutes. I unlinked Signal and turned off desktop sync. Wake-ups dropped from 42 to 7 an hour, but the drain didn’t change.
- Wi-Fi: no difference. About 55 mA with Wi-Fi off or on.
- Offline+ switch overnight (3 nights): about 6 mA, or 0.2% an hour. One night went from 35% to 33% in 8 hours.
So on my phone almost all of the standby drain comes from the cellular modem staying connected, about 9 times the Offline+ figure. That seems to match richardkrikler’s 4.6 mA with cellular off vs 84 to 102 mA on LTE.
One more thing from the logs.. Like richardkrikler, I see Doze switched off. With one SIM inserted, the empty second slot also reports “no network” to the system about every 23 seconds, and battery stats count this as “out of service / searching” 94% of the time. I don’t know how much battery it costs…
For now I flip the Offline+ switch at night. Does anyone know if this LTE standby drain is expected? and is there a way to turn off an unused SIM slot? I’m sending the details to Mudita support, too.
yes, all mobile devices will ping cell towers very frequently to find the best/closest tower to make sure your connection is stable.
Very common for battery drain to be contributed to this, especially if you live in an area with patchy signal quality, as the device will be pinging the towers even more frequently in order to establish and maintain its connection.
references:
https://www.reddit.com/r/iphone/comments/11zm4g/does_lte_drain_battery_noticeably_more_than_using/
Thank you! That makes sense, so it sounds like it’s probably not attributable to the empty SIM slot even though frequent pings show on the log, since it never connects. Still curious why it’s not inactive when empty, but maybe it’s a non-issue.
I wonder how switching Offline+ mode on while driving/moving between towers would compare w/ leaving network on. Maybe I’ll test on my regular work commute and check the logs ![]()
using offline+ is pretty close to turning the phone off, so yes will likely save you some battery as you wont be pinging towers.
I think the old-school method of changing one thing at a time would be the best method if you or anyone is facing severe or particularly unexpected battery issues. Remove all your side-loaded apps ( or better yet do a full reset of the phone), then add them back one-by one to see which has the biggest impact.
