I realise it’s a personal taste, but Tidal allows you to download for genuine offline listening as part of their premium subscription. Instead of merely synchronising via an internet connection, I utilise this service by seeing a tutorial at hegoal and have my files on my laptop as well.
I’m new here and stumbled upon this post about finding alternatives to the smartphone model. I think it’s great that you’re looking for ways to segregate your life, work, and family time.As for syncing Spotify playlists and Audible/Kindle whisper sync, have you checked out the Pure phone’s app? It might have the functionality you’re looking for. But if not, I’ve heard of this product on Amazon that syncs Spotify playlists via an app to an offline device. It could be worth investigating.By the way, have you heard of https://songlifty.com/spotify-artist-profile/? It’s a site that helps indie artists promote their music online and get more exposure on Spotify
How to Convert Audible Books Offline to Listen on Spotify
- Step 1 Install and register AudKit Audible AAX Converter. …
- Step 2 Import Audible AA/AAX audiobooks. …
- Step 3 Reset Audible output settings for Spotify. …
- Step 4 Make other customization for Audible books. …
- Step 5 Download Audible audiobooks for Spotify.
Good post! Instead, I use Tunelf Spotify Music Converter for Windows. So far, works well with my laptop and converts Spotify Music to MP3 in batches quickly. A very useful tool to use!
Well, I also have a Spotify music downloader from AudBite that helps me to download my favorite playlists for offline listening. It additionally supports podcasts, songs, albums and audiobooks. A great option for me to remove ads from Spotify with lossless quality!
Indeed, I found another tool called Tunelf Tidal Music Converter to help me download Tidal for free. So I don’t need to pay any for Tidal. Differing from recorders, this converter can keep the original sound quality. Anyway, it is reliable.
To sync Audible to Spotify, you have to convert Audible books to MP3 first. Here, ViWizard Audible Converter can do a good job. After that, you can upload Audible MP3s to Spotify for listening.
Or you can convert Audible audiobooks as files, then you can play them offline on other devices without a smartphone. Tunelf Audio Converter is the best converting tool I used! It is worth to have a try. I’m also hope may life away from phone as possible.
