Android System Messages
Hi,
I like the Mudita Compact and the idea of a silent smartphone. I connect it with my Pepple smartwatch, so that no sound or vibration from the phone is necessary.
There are some flaws regarding missing configuration options:
On the smartwatch I receive messages about settings, that I cannot turn off or change:
  • 2 GB limit of the mobile network - every 10 MB a new message
  • 20% limit of the battery - every percent a new message
Another setting I miss:
  • PIN of the SIM card - no change is possible
Is there an app, that makes the missing settings on the phone visible ? Or will the new version of the OS fix that anyway ?
@headcrash I just want to make sure I understand what you’re asking about. Are you looking to access the Android settings that aren’t available in Kompakt’s settings menu?
Are you getting these messages about network usage on your Mudita Kompakt as well?
If you want to change the SIM pin, our team also confirmed that dialing this works:
**04OLD_PINNEW_PIN*NEW_PIN#
That MMI dialling code is incorrect. In truth it’s:
**04*OLDPIN*NEWPIN*NEWPIN#
To change your SIM PIN from “1234” to “1111”, for example:
**04*1234*1111*1111#
It is baffling why Mudita hasn’t provided a more convenient tool to perform this operation. It’s fiddly nature is proven by how difficult it is for the Mudita team, who allegedly confirmed that the incorrect code works, to get it right on a community forum.
Thank you, Urszula and Ocelot, for the tip how to change the pin. May be it would be more useful to have the possibility within the GUI settings-dialogue.
In genereal I posted the message to warn you, that some android features are hidden, but still active. Without a smartwatch, you will not realize it - but the messages are there and the frequency of their repetition is not normal. So in order to calm down the brabble of the phone, I would like to reset the counter of the network-traffic and shut up the battery-warnings after each percent that is under 20%.
Is there an app, that can do the trick ?
Greetings!
I got these messages too and was able to change/disable them both. You will need to install the app ‘Activity manager’ first before you can reach these settings.
After installing the app, open it, search ‘settings’ and choose ‘com.android.settings’.
Then, for the battery percentage message:
Search ‘battery’ and choose ‘Settings$BatterySaverSettingsActivity’ (there are two, either will work). Here, you can lower the percentage to at least 5% (you might have to choose ‘set a schedule’ first to reach these settings), so that now you will only receive a message if your battery drops below the percentage set by you. The red LED light at the front will also not light up until you reach this percentage. I think choosing ‘No schedule’ means you will never get a battery percentage warning message, but I haven’t tried that yet so I’m not sure. Edit: I tried this, and the LED lit up again when my battery percentage dropped below 20%, so this doesn’t work :frowning: but enabling ‘Use a schedule’ and lowering the limit does work!
For the 2GB limit of the mobile network:
Again, in Settings, search ‘Data’ and choose ‘Settings$DataUsageSummaryActivity’. Scroll down and choose ‘Data warning & limit’. Here you can either disable the warning messages or set a new limit for the data warning.
Hope this helps!
Edit: it just occured to me that Activity Manager might be able to change/disable the SIM pin, so I went to check. Turns out you can!
Again in ‘com.android.settings’, search ‘SIM’ and choose ‘Settings$IccLockSettingsActivity’. Here you can either disable the SIM pin or change it.
Dear superanette that was super !
Exactly, what I asked for. I managed all the settings and now my Pebble is as silent as my Kompakt.
Thank you for your help!
Greetings
Great, happy I could help!
Thank you for flagging this. I was typing too fast.
