Alright so, I use Gentoo GNU/Linux as my daily driver and I have tried to sync my Pure, but it doesn’t work on Gentoo. When I tried it on Trisquel GNU/Linux it did work, so I strongly suspect it must have to do with the kernel modules. I use a custom kernel (Linux 6.1.19-gentoo) and not all the options are enabled by default. So I was wondering which kernel modules I would need to compile for Mudita Center to recognize and successfully sync with my Pure. Help would be appreciated.
@emna Thanks for your question. I’m not a Linux user, so I’m going to need some backup from my team to help answer your question. I’ve already reached out to them.
I will get back to you as soon as I get some info.
