Did you download the WhatsApp app on your Mudita Kompakt? Where did you download the WhatsApp APK from?
i have this problem too
the thing is that my sim card was flagged by whatsapp when about 2 years ago i used a modded whatsapp
but now most of the modded whatsapp apk’s don’t work on a normal device
but they can work on custom ROM’s or degoogled OS (just like the Mudita OS-K)
so Whatsapp doesn’t allow the flagged mobile number to be used on a degoogled device.
i tried everything but nothing works right now you only have 2 options either get a new SIM
or
login whatsapp on a normal non-modded phone and you can link it with beeper and use on the kompakt but you will have to open whatsapp once on the main device every 13-15 days
i currently use Beeper only.
Thanks for the replies! I started by grabbing WhatsApp from the Aurora store, then when that didn’t work, I pulled the APK from the WhatsApp website and put it on the phone through the Mudita Center.
So you think it’s a SIM card problem rather than a phone number problem. If that’s the case, I think I’m gonna just head to T-Mobile this week and get a new SIM. I’m really trying to get rid of all dependency on a secondary phone, so I’m hoping to avoid the beeper option (though it is a good alternative solution if all else fails). I’ll get a new SIM card this week and check back in afterwards. With the new SIM, do you think it’ll matter if I put it into the Kompakt right away, or should I put it in the Iphone and then move to the Kompakt?
Hi @radsports, did your solution with a new Sim-Card work? I am having the exact same problem here as devamjaglan after my WhatsApp-Account got hacked. Could you keep your phone number and just replace the SIM?
