Wallet — Community App Review
Version: 0.1.0
Wallet shows a card as a barcode a scanner can read off the Kompakt’s screen: as large as the panel allows, black on white with the margin a scanner needs, every bar a whole number of pixels wide so there is no grey edge for the panel to soften. The number is written under it for a cashier to type when a scanner will not read, and the screen stays awake while a card is open.
To add a card, scan it with the camera, type the number and choose the kind of barcode, or read it from a picture: a screenshot, a photo, a PDF ticket, or an Apple Wallet pass file. A picture shared from Gallery, Email or Messaging comes straight in, and so does a .pkpass opened from Files.
Tickets and boarding passes have a first and a last day; the list says when one has expired or is not yet valid, and “Add to calendar” puts the days into Calendar. Boarding passes use Aztec and PDF417, and both are drawn. Every kind Catima knows is here, Codabar and Code 39 among them, which many library cards use.
Favourites sit at the top with a star. Groups sort cards into kinds, and the order is by name, last used, last added, or soonest to expire. A finished card is put away rather than deleted. Cards come in from a Catima, FidMe or Voucher Vault export, and every card goes out as a Catima file.
The camera is the only permission, asked when Scan is first pressed, and there is no internet. Built on Catima; source, and the licence it inherits: GitHub - wanderwildwood/satsuire: Wallet (札入 satsuire) — loyalty cards, tickets and boarding passes as barcodes a scanner can read off e-ink. Camera only, no internet. · GitHub — GPL-3.0.
Which scanners have you met that a phone screen would not get past? A ferry gate and a library desk have been the measure here.
