Hello everyone,
Is voice to text a planned feature?
Thanks!
Also curious about this! An Eink experience is greatly enhanced by voice to text. I remember hearing that they were planning to add this feature. You could always download Gboard and use the feature through that keyboard, though Iāve heard the experience is slower.
Iāve mentioned this in another thread but it would be nice to have some sort of active blog page where Mudita lists the features theyāre planning to implementing after launch (maybe even with rough time estimates as well).
Jose Brionnes showcases the G Board functionality (including speech to text) in his Mudita review.
I would be hesitant to use any Google-based apps and services on the Mudita Kompact. Native speech-to-text capability would be great. @urszula are you able to confirm if this is presently supported or will be in future?
Thanks.
You donāt have to use Google Gboard. You can use FUTO (open source) and get voice to text as well. While a native solution is definitely a plus, voice to text is not easy to maintain in multiple languages.
How do you change the keyboard to a different one? Or change back?
Settings>Keyboard>Change
hi jose thanks for the heads up on that keyboard , so far testing it and like,im using it on bigme hibreak, gboard start to show me diferent dont know why
seems really cool this keyboard
Native voice to text would definitely be nice!
Thanks, @Jose_Briones. You are a very knowledgeable and helpful digital minimalism advocate. A warrior fighting the good fight.
@anon80904485 This is a feature that our team is seriously looking into. Itās a much-requested function. Iāve asked them for some more info on this topic.
FUTO have a good keyboard project: FUTO Keyboard
Re voice input: FUTO Voice Input
Because FUTO runs offline, Iām curious how the AI predictions and voice input will affect battery life. Has anyone tested? @Jose_Briones
No large issues tbh. FUTO is well optimized.
Voice to text would be awesome! Not a deal breaker for me but it is a nice to have
@Jose_Briones, Did I understand correctly voice-to-text input is possible in FUTO? In Futo Keyboard Settings there is a āVoice Inputā option to āDisable Built In Voiceā (Use voice input provided by external app.) It find that wording confusing. If itās unchecked, is it disabling FUTO Keyboardās voice-to-text? Either way, whether itās checked or unchecked, I never see the microphone on the FUTO Keyboard. Can you suggest anything? Many thanks.
@petemeister I think @Jose_Briones demonstrated voice-to-text on one of his videos with Mudita Kompakt. However, Iām not sure what he sideloaded.
Leave that one unchecked. Go to Language and Models. Under the specific language, you will see āvoice input.ā Click that and explore. Then download the model you want. After that go back and instead of explore, this time click import and select the model you downloaded.
Thanks for this @Jose_Briones. I fumbled my way through and ended up with two versions of FUTO keyboard and FUTO Voice Input using two versions of English (UK and US), but in the end it worked. Hooray! Iām much obliged to you for your help. Iām surprised just how good it is. It still gets confused with some words. Hayfever often comes out as āHey! Steverā which I imagine to be some Aussie making a wisecrack at Steve Jobs, but itās mostly on the money.
@petemeister @Jose_Briones so with your last two messages what is the proper way to get it working? Sorry Iām a little confused
