Mudita says about its Mudita Moment watch straps,
We recommend changing your straps every six months due to hygienic reasons.
I wondered what “hygienic reasons” meant when I ordered my Mudita Moment with four straps, but now I know.
- Cork straps – both natural (included with the Moment) and black – can become smelly from wrist perspiration after a few weeks of wear.
- Bananatex® strap, because it has a cork backing, can become smelly from wrist perspiration after a few weeks of wear.
- Desserto® strap, which is made from cactus, seems to avoid this problem.
So, here are my tips for anyone planning to order the Mudita Moment, which comes with the natural-color cork strap.
- If you are ordering the Moment only with the included natural-color cork strap, then check the Interwebs for advice about how to clean cork. I found advice to use a high-strength (e.g., 95%) isopropyl alcohol, and this seems to work for removing the smell from the cork straps and from the back of the Bananatex strap.
- If you can afford it, then order the Moment along with a Desserto strap (gray or black), which seems more resistant to developing an odor from wrist perspiration.
- If you want to “go rogue” with your Moment, then order the Moment with the included cork strap but then buy, for just $10-20 (US), a soft silicone replacement band for the Garmin Forerunner 645, which has the same spring-loaded fittings for easy swapping with the Mudita cork strap. You can then rinse the silicone band daily with water to keep it clean, without “soaking” the Moment itself.
