Teaser for upcoming MuditaOS K 2.0
Will the integration of Google calendar be something that can be disabled, and is it enabled by default on the OS update?
I personally do not wish to have anything linked to Google on my Kompakt
Yes and no
It’s off by default
This may have been asked but will we be able to remove pre loaded apps we don’t use?
It’s actually DISABLED by default. You have to make the intentional choice to connect & sync your calendar.
Currently there is no native way to do this. Our team is exploring options connected with this topic. However, I do use a 3rd party app- I use Batch uninstaller to remove apps I don’t use.
Ooooooh! November has arrived. I feel like a child on Christmas Eve, awaiting the arrival of 2.0 presents!
thanks for this. tried it on the mudita apps like chess and calendar and it doesn’t work. i guess you just mean for apps that you’ve sideloaded.
It seems to me that it would make sense to build app deletion functionality into Mudita Center
This had been passed on to the team. Thank you for the feedback. With the next MuditaOS K 2.0 update, uninstalling will be available directly on Mudita Kompakt. You will be able uninstall an app directly from the phone.
it could be. I’ll do some troubleshooting and see if other uninstallers work better.
