I’m curious if there’s a way to (ideally wirelessly) sync messages (SMS/MMS) between the Mudita Kompakt and a computer.
My preference is to receive and respond to all messages on my computer (MacBook Air) when I’m at my desk with access to a full keyboard.
However, when I’m on the go, I’d like to receive those same messages on the Mudita Kompakt so I can quickly screen them, determine their urgency, and - if they’re not timely (and most aren’t!) - simply ignore them and review/respond later when I’m back at my computer.
I’m wondering if there are any solutions or workarounds for this type of setup with the Mudita Kompakt?
Thanks in advance for any thoughts/knowledge you may be able to share on this topic.
There appears to be a current workaround here (thanks to gezimos for the hot tip)! I’m testing it now and will update this post in ALL CAPS shortly
UPDATE: I WAS ABLE TO GET KDE CONNECT WORKING INCREDIBLY WELL - DETAILS (INCLUDING TROUBLESHOOTING) IN THE POST LINKED BELOW. HOPE IT PROVIDES UTILITY TO OTHERS!
KDE Connect seconded. You can also try PlainApp. They both sometimes have trouble connecting, but KDE Connect has been a bit more reliable for me. I use it both on Linux and my work Windows laptops.
