Anyone has achieved that? All my headphones don’t have a prev/next song button.
Hi there,
Spotify is not a supported app and you have sideloaded it so it is normal that system was not prepared for it.
Also something i noted, if you are used to just turning your bt headphones off and music stops instantly in regular smartphones, here it is paused but the app is still opened and drawing power like it would while streaming music, go into app and manually stop the music before you turn off your headset for less power draw.
Yep, I understand the side-loading aspect. I hoped that there would be a trick that allowed it as for other things. Thanks for the manually stop the music trick.
