Hey all. So i sideloaded spotify, and its jsut too heavy. Understandably.
So someone said they used Spotify Lite but they seen to have some brutal password login issues. Passwords not working etc.
Anyone experienced the same thing?
Spotify Lite has been discontinued so I wouldn’t recommend it - I’ve personally switched to CalmMusic although it’s painful to lose access to all my playlists and saved music
Yes not a bad idea. How annoying though
For the best music streaming experience I would use an internet connected device to listen to music from the internet.
As I see it using a sideloaded internet dependent music app was not the intended use of the Kompakt phone.
Mudita Kompakt is an internet connected device, Wifi or mobile data, but of course I am fully aware this is not for its intended purpose.
the Kompakt is an internet connected device though?
Internet capable, yes.
The Spotify app does work on the Kompakt, but its dark mode (which you can’t turn off) causes the display to lag considerably
That’s a spotify issue, not a kompakt issue, however…
If MuditaOS had a screen Invert option for specific apps that might be a work around for such cases (reverse black and white to white and black)..
