Ringing someone stops after 30 seconds... Solution?
Hi…
I have a problem I also had with f.e. Fossify Dialer… But never with other ROMs and phones like aosp dialer, lineageos dialer etc.
When I call someone the ringing stops after 30 seconds and calls ends directly. That is why I stopped using fossify dialer too on other phones.
When using aosp gsi rom on other phones, lineageos, iphone etc. ringing is much longer. Very annoying since my most used number is someone taking forever to answer the phone. Is there any solution to this?
If not, can Mudita please change this with the next update!
It’s regarding ringing someone else. Calls don’t get interrupted and don’t stop. Just ringing someone stops that early.
Thx.
According to Google:* An outgoing call stopping after 30 seconds usually points to network timeout or carrier routing issues rather than a specific dialer app flaw. When this happens across multiple phones and dialers like Fossify Phone, the root cause is typically tied to your cellular network, VoLTE settings, or carrier profile rather than the user interface.
What I’d do is redial the number but I can see that being a problem because usually after 5 rings the recipient goes to voice mail.
Thank you but you should have read my post a bit more!
As I said in my first post (!), with every other phone and system it is working perfectly fine. It rings for around 90 seconds before it stops. iPhone, different AOSP Android phones. Same sim card. So it can’t be the network and it can’t be the other number. It must be a setting within the dialer app or muditaos. So your answer was something I already ruled out in my post.
@twuki Thank you for flagging this. Is this also happening with the Native Mudita Phone APP? Or are is this only happening with Fossify Dialer?
I haven’t used fossify dialer for a long time because of this problem. But a long time ago FD had the same problem as the native mudita dialer app.
It is only on the native mudita kompakt dialer app. On the native aosp dialer app on my other phones, on lineageos, on iPhones it is ringing for around 90 seconds at least. ONLY THE MUDITA DIALER HAS THIS PROBLEM of all the phones and apps I am using atm. Same sim card, all other phones ring 90 seconds. Can’t be my network and neither the other caller’s network.
@twuki I will ask the team about & and I will also try to see if I can recreate this issue.
What network provider do you use?
