A resource thread for users struggling with ATT connectivity. Feel free to share what worked for you.
My situation
- ATT prepaid
- Active SIM from prior phone
- Coming from older Android (galaxy S8)
- WiFi calling and SMS work
- ATT warning text about how the phone is supported
Issues
- No SMS
- No calls
- Icon indicates no mobile signal
- No idea what APN settings to use
- New APN will not save
- APN saved but still no LTE signal
Summary
Use the ATT-recommended NXTGENPHONE APN settings linked below, but do not change MCN from whatever loads by default. Turn on roaming.
Details on how I fixed the issues above
- Forum posts indicated I should try replacing the APN settings but didnāt indicate what settings to use. I found the page from ATT linked below.
- Mudita Kompakt supports 4G so I used
NXTGENPHONEsettings - NEW ISSUE: The new settings did not save when I clicked āsaveā.
- I tried swapping the Sim back to the old phone and setting APN, but the problem reoccurred on the Mudita, where the APN was set for āENHANCEDPHONEā (5g).
- I remembered some random comment about MNC settings blocking save so tried creating a new APN with ATTās
NXTGENPHONEsettings except I did not change the data that was already in theMNCfield. Clicked save and it saved successfully. - NEW ISSUE: ATT
NXTGENPHONEAPN saved but still no signal. - Turned on roaming (in Settings > Network > Mobile Network and got an LTE wireless connection successfully.
- Toggled off the antennas with Offline Mode switch. Toggled back on. Turned off roaming. LTE connection still works. (no idea whether turning off the antennas made a difference, but I did it so itās worth recording.)
Settings page I (mostly) got my APN values from
@weekday_warrior Thank you for sharing. I updated your links, so they are easier to click for our community.
