Remove Animations
Just thought I’d share a setting change I’ve found really useful - you can’t access the standard android accessibility menu through the settings app so you will need to use something like the settings search function in InkOS to access it - search for “remove animations” and toggle it on. I’ve found this greatly improves the experience in many third party apps since the slow refresh rate of the Kompakt’s screen causes transition animations to take a while.
@ArmchairSetup Thank you for sharing. I will share this info with out team.
