We’ve created a simple radio player app for Mudita devices that allows you to listen to online radio stations. You can also add your own streaming URLs and enjoy your favorite stations.
Download & Installation
The app is available for download at the link below. Simply download the ZIP file, extract it, and use Mudita Center to transfer the app to your device.
- **QR code scanning:** no more typing stream links. In Favorites tap + Link, then the scan button next to the link field, and point the camera at a QR code. The link fills in by itself, and no picture is saved.
- **In-app language:** under About → Language you can choose Croatian, English or Spanish, or keep your phone’s language. Country names follow your choice too.
- **How to use:** a new section explains how to find a station, save favorites, add your own link and move through pages.
- **More detailed privacy:** what’s stored on the phone, who sees what, which permissions the app uses and how to delete your data. The app is now left out of phone backups.
- **Terms of use and legal notice:** new sections under About, including a contact for station owners.
- **Camera only when you need it:** permission is requested the first time you scan, and the camera is used only while the scanner is open.
Download the ZIP, extract it and install Radio-1.4.apk with Mudita Center. It installs over the old version, and your favorites and custom links are kept.
works great! i’ve been looking for something like this ever since i got my kompakt. thank you SO much for making this! the only thing i find myself doing by mistake is when pressing back button on my phone it takes me off the app completely - but this is probably an issue with me, so i have to be careful to stop doing that!
This app sounds great, after installing it though the app is coming up with an error: “Couldn’t load the list - check your internet connection”. My connection seems fine. Any ideas? Thanks.
Review for version 1.4
Thanks for reporting this issue!
Could you please let us know at which step the error appears? Does it happen immediately when you open the app, or when you’re browsing or searching through the list of countries?
We’d also appreciate it if you could provide a few more details about what happens before the error appears, and any other information that might help us reproduce the issue.
This will help us identify the cause and fix the problem in a future update. Thanks for your help!
Podcast Support: Discover, browse, and listen to podcasts directly within the Radio app.
Improved Design: A refreshed, more intuitive interface optimized for the E Ink display.
Back Button Fix: Fixed the issue where pressing the device’s Back button would unexpectedly close the app.
UK Connectivity Fix: Resolved the server connectivity issue that prevented some users in the United Kingdom from loading radio station lists.
Connection Recovery: If a radio station isn’t playing, try turning Offline Mode on and then off again. This refreshes the device’s network connection and may obtain a new IP address, allowing previously unavailable stations to reconnect.
Improved Reliability: Better handling of server availability and connection errors for a more stable listening experience.
