Parked review by wander
Parked — Community App Review
Version: 0.2.8
Parked remembers where you left the car, and how long you have.
Press Mark this spot when you get out. Parked takes a fresh position from the GPS, waits a few seconds for a good one, and keeps it with the date and time and how exact it is. You can add a note, like “level 3, row C”, which is the part a garage needs.
On the way back, press How far? and it tells you how far away the car is and which way: “190 ft NE”. Within the phone’s margin of error it says “About here” instead of a number it cannot stand behind.
Open in maps passes the spot to whichever maps app you use, such as HERE WeGo, Organic Maps or OsmAnd. Share sends it as plain text with a link. The last five spots are kept.
The meter takes 30 minutes, an hour, two hours, another length, or the time printed on the ticket. It rings 10 minutes before the time is up (Settings changes this) and again when it ends, with the alarm sound, over the lock screen, and it keeps working after a restart. On a Kompakt it asks once to switch Parked on in DuraSpeed, so the alarm is not shut down.
Distances are in meters or feet, as your phone’s country uses them, or as you set them.
Location is used only when you press a button, never in the background, and there is no internet permission, so where you parked cannot leave the phone. A roof hides the sky, so mark the spot at the garage entrance and put the level in the note.
Source and license: GitHub - wanderwildwood/okiba: Parked (置き場 okiba) — remembers where you left the car. One button marks the spot, another gives the distance and bearing back. A parking meter rings before your time is up. No internet permission. · GitHub — GPL-3.0-only.
