Paper CALC review by deberly
Paper CALC — Community App Review
Version: v1.37
Hi all,
I couldn’t find a calculator that looked right on the Kompakt’s E Ink screen, so I made one. It’s black and white, has no animations, and uses big digits.
What it does:
Shows the result as you type, with the normal order of operations (2+3×4 = 14)
One key for parentheses that opens or closes as needed
An f(x) key for π, √, x², powers, 1/x, ± and n!
Pressing = saves the operation to a history of the last 20
Copy button: copies the result, or the whole operation (your choice)
Vibration on key press, with three strengths or off
Choice of decimal separator (, or .) and thousands separator (. , or space)
10 languages
It doesn’t need Google services, has no ads and doesn’t ask for internet access.
Download the APK here: Release Paper CALC 1.37 · mdeberly/paper_calc · GitHub
It’s a hobby project and I wrote the code with help from Claude AI. Feedback and bug reports are welcome.
Maximilien
