NFC for keycard
I’m wondering if anyone has been able to sideload any app to use for NFC keycards. I have seen a lot of posts about people wanting NFC for payment cards, or for Yubi keys, but none that quite match what I need. I’m in grad school and the university has us do ID cards on our phones so that we get into the locked buildings with our phones.
I have already sideloaded F-Droid and the Aurora store. I see a lot of things when I search NFC in F-Droid but none of them seem relevant. I see a lot of things in Aurora that probably are relevant but I’m not sure I trust any of those. How can I unlock doors with my Kompakt?
Hi jess, welcome. The Kompakt does have working NFC, so the radio isn’t the problem. The catch is where your university’s ID lives. Most campus phone IDs come from Transact, CBORD or HID, delivered through Google Wallet or the provider’s own app, and those usually depend on Google Play Services, which the Kompakt doesn’t have. A general NFC app from F-Droid can read tags, but it can’t copy a building credential; those are locked to the official app on purpose.
If your school uses HID, HID’s own Mobile Access app is worth a try from Aurora. It can open doors over Bluetooth as well as NFC, and it may run without Google, though I haven’t been able to check that myself.
If you can find out which system your school uses (the ID office will know, or it’s often named in the setup instructions), that tells you whether there’s any path at all. In the meantime I’d ask the ID office for a plastic card. Most schools still issue them for people without a supported phone, and you could stick that in the back of this case and it’ll work essentially the same way (I do this with my credit card).
@jessc NFC is OFF by default in Mudita Kompakt. However, I do recall some discussions on this forum & REDDIT that people got it to work for work entrance cards or something similar. I will ask our team if there’s a workaround.
In the meantime, I would love to hear what the community has tried & what worked or what didn’t.
Thank you, both! Wander that was an extremely helpful explanation. I’m reaching out to the card office to see if they know which provider they use.
So the school uses Transact, and they recommend the Transact eAccounts app, which sounded promising. Aurora did have this app, but I get an “eAccounts App stopped working” error when I try to launch it. I assume it must need Google services or whatever. I’ll talk to the school and see if I can get a physical card.
I know a wallet app for payments might be out of reach, for reasons discussed in the thread on that topic, but I would appreciate, Urszula, if you can pass along the suggestion for some sort of native app that at least covers the non-payment wallet uses. Thanks for all that you do!
That fits, jess. With Transact the phone ID gets set up through eAccounts but ends up inside Google Wallet, so even if eAccounts ran, the door credential would have nowhere to live on the Kompakt. The plastic card is the right call, and it’ll work from the back of a case.
For the rest of what a wallet does, Wallet (on Community Apps) keeps loyalty cards, library cards and anything with a barcode or QR code, all offline. If your ID has a barcode for the library or dining hall, you can add that too. What it can’t hold is the door key itself. That needs Transact’s keys, and they only hand those to Google and Apple.
