Music Box review by wander
Review updated by @wander
  • Version: 2.15.0 → 2.16.0
  • Checksum: ac6574cf98f54a4681d02431196d46f644704a14c9ddff693a0b88a93a6df9ec → c48a56ab44ac39a157efeb8febb3025d617756fc174f33a4f80e5a4b94ebbc89
View current review
Review for version 2.16.0
User rating: ★★★★★
Hello Wander,
thanks for this clean app interface - I really like it.
I’m currently struggling to connect to my server. I’ve been trying to connect to my Subsonic server, but I keep getting the following error message:
“Token based authentication not supported.”
My Subsonic server is the Music app hosted on my Nextcloud instance.
The connection works fine when using the Tempo app, though.
Do you have any idea what might be causing this or how to fix it?
Thanks in advance, Max
  • Version: 2.16.0 → 2.16.2
  • Checksum: c48a56ab44ac39a157efeb8febb3025d617756fc174f33a4f80e5a4b94ebbc89 → 76aa5fa97afda8b3586e4f030e18e79b8e6019df654a75374a09f8895666cac5
View current review
Review for version 2.16.2
@mx22 Thanks, Max, that was a clear report. Nextcloud Music doesn’t accept the token sign-in Music Box used, only the older password form, which is why Tempo got in and Music Box didn’t.
Music Box 2.16.2 now notices when a server turns tokens down, switches to the password form and remembers it for that server. The server screen says when that’s happening.
For Nextcloud Music, use the address and username shown in the Music app’s own settings (it ends in /index.php/apps/music/subsonic), and the API password you create there, not your Nextcloud password. Since the password then travels with each request, use an https address when you’re away from home.
User rating: ★★★★☆
Could you make the scroll bar optional with a toggle? Also not sure if the update with the ability to change artist etc has been updated! TY
User rating: ★★★★★
@wander
It’s working now!
Thanks so much for your help. You’re awesome Wander!
I really appreciate the support.
Best regards, Max
Both are in: since 2.17.0 you can long-press an artist and choose File under…, and since 2.17.1 the letters down the side are off unless you switch on “Letters and page dots” in Settings.
User rating: ★★★★★
This app is amazing! I have a question: how does the “keep playing similar songs from YT” work? I’ve already logged into my google account and downloaded 3 songs. When I’m under the “songs” tab and hit play, the app plays the 3 songs that I’ve downloaded. But, after the last song is finished, it stops playing
Thank you! Until now it only followed songs streamed from YouTube, so after a run of downloads the queue simply ended. In 2.18.4 a downloaded YouTube song at the end of the queue brings similar ones after it too, as long as the phone is online. Until you update, playing a song from YouTube search starts the run.
User rating: ★★★★★
A quick question – would it be possible to enable a YouTube link one receives in Signal, Messages, or Email apps to open in Music Box? Thanks!
User rating: ★★★★★
My apologies if this has been implemented – would it be possible to allow a YouTube song or album link to be pasted directly into the Music Box search to access music?
Thanks!
@zyny Both are in now, and no need to apologize: they were good asks.
Since 2.18.21, a YouTube or YouTube Music link you tap in Signal, Messages, Email or a browser can open in Music Box: choose Music Box when Android asks which app should open it.
2.18.23 adds the other half: paste a song, playlist or album link into Music Box’s search and it shows that one song, or the playlist or album with its song count, ready to play. YouTube Music album links you tap elsewhere open in Music Box too.
User rating: ★★★★★
Thanks, Wonder. I appreciate the update and the information.
A few observations I noticed since updating to Music Box 2.18.32.
The YouTube link sent in Signal still doesn’t recognize Music Box as one of the apps, but opens in EinkBro, which i currently have set to Kompakt’s default browser.
I also noticed a small discrepancy when adding YouTube and Radio links over Wi-Fi versus cellular data. I noticed that it works perfectly later, especially with radios, where adding and searching for songs by pasting YouTube links doesn’t play the correct radio streams or give an error message when attempting to play a YouTube song. I experienced this a couple of days ago; I’ve been testing it since this morning on home Wi-Fi, and it seems fine, but I’ll keep you posted.
Thank you!
@zyny Thank you, that was a real gap. Android 12 only offers an app for web links once you have said it may open them; until then they go straight to the browser, which is what you saw. Music Box’s Settings now has a row, Open YouTube links in Music Box, that takes you to the page where you tick the YouTube addresses. After that, a link tapped in Signal opens in Music Box.
On Wi-Fi versus mobile data: yes, please keep me posted. If it happens again, the time, the link or station, and what you saw on screen would help me find it.
2.18.30 is up: Release v2.18.30 · wanderwildwood/jimeikin · GitHub
User rating: ★★★★★
You’re welcome, Wonder - thank you for your quick update!
Does this require Signal to integrate with the Messaging app, or can Music Box now open links from the official Signal app, or from other email or messaging apps? I ask because when I try to open the YouTube link sent to me via the regular Signal app, it only opens in EinkBro (there’s no other option or way to copy the link). Then, when I want to share the link using the EinkBro share feature, it does list Music Box as one of the apps and lets me open the link.
Zvony
No need for Messaging: Music Box opens YouTube links from any app, the official Signal app included. The catch is Android 12 itself. It sends a web link straight to the browser unless you’ve told it that another app may open that address, which is why Signal only offered EinkBro.
Since Music Box 2.18.30 there’s a row in its Settings, “Open YouTube links in Music Box”, that takes you to Android’s own “Open by default” page for it. Turn on “Open supported links” there and add the YouTube links it lists, and a YouTube or YouTube Music link tapped in Signal, an email or anywhere else will open in Music Box. Sharing from EinkBro, the way you found, keeps working either way.
